Small rivets
Mode
Tool
Tool set
Small Rivet
Fasteners
Multiple rivet tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a small rivet:
Click the tool and mode.
Parameter
Description
Diameter
Select a diameter in inches
Length
Enter the length under the rivet head (or overall length for the countersunk rivet)
Head Type #1
Select a head type for one end of the rivet
Head Type #2
Select a head type, if any, for the other end of the rivet
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the rivet with center line(s)
Large rivets
Rivets (DIN)
Tubular rivets
