Tubular rivets
Mode
Tool
Tool set
Tubular Rivet
Fasteners
Multiple rivet tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a tubular rivet:
Click the tool and mode.
Parameter
Description
Size
Select a size in millimeters
Length
For a custom length value, deselect Use Standard Length Increments and enter the length
Form
Select one of the rivet types
View
(2D only)
Select the 2D view
Show Uncompressed Length
(2D only)
Displays the uncompressed rivet length
Automatically adjusts the length to the nearest increment based on DIN standard sizes; deselect to enter a custom length value
Show Center Line
(2D only)
Draws the rivet with center line(s)
Large rivets
Small rivets
Rivets (DIN)
