Woodruff keys
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Woodruff Key
Machine Components |
Multiple key and woodruff key tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a woodruff key:
Click the tool and mode.
Parameter |
Description |
Standard |
Select Imperial or Metric |
Nom. Size (in) or (mm) |
Select one of the standard key sizes |
Key Type |
Select the key type
Depth of Keyseat (shaft) / Depth of Keyseat (hub) |
Displays the depth of the keyseat shaft and hub, determined by the standard size selected |
View (2D only) |
Select the 2D view
