Angle between two reference lines
Mode |
Tool |
Workspace: Tool set |
Shortcut |
Reference Lines
Angular Dimension
Fundamentals: Dims/Notes Architect, Landmark, Spotlight: Basic and Dims/Notes |
. (period) |
To dimension an angle between two references lines:
Click the tool and mode, and then select a Dim Std (dimension standard).
Click to set the start of the first reference line.
A reference preview line displays.
Click again to set the end of the first reference line.
A second reference line preview displays.
Click a third time to set the end of the second reference line.
An angular dimension preview displays.
To select a different angle—for example, spanning the opposite direction—move the cursor until the preview displays the desired angle.
Click again to define the angle of the dimension.
