Measuring in degrees
The Protractor tool measures angles in the drawing, and temporarily displays the degrees measurement in the Data bar. There are two modes for the tool.
             Mode  |
             Description  |
             Angle from Two Segments
             Calculates the angle between two objects or object sides that are linear—rectangles (including rounded and rotated), lines, polylines, and polygons. This mode cannot measure circles, ovals, or arcs, and it cannot measure between parallel lines.  |
             Angle from Three Points
             Measures an angle between three points in the drawing area  |
Angles between objects or object sides
             Mode  |
             Tool  |
             Workspace: Tool set  |
             Protractor
             Fundamentals: Dims/Notes Architect, Landmark, Spotlight: Basic and Dims/Notes  |
To measure the angles between objects or object sides:
Click the tool and mode.
Move the selection arrow over the first side of the angle to measure.
Click to select the side, and then move the cursor to the other angle side.
The angle displays in the Data bar.
Note the angle, and then click to end the measurement.
Angles between three points
             Mode  |
             Tool  |
             Protractor
To measure angles between three points:
Click to set the first point.
Click to set the second point.
Move the cursor to the third angle point.
