ArchSpot03585.pngCustomizing seating symbols
It is possible to customize the seating symbol attributes to create a new hybrid symbol definition for use in seating sections.
From the Arrangement pane of the Seating Section Settings dialog box, select a Seating Symbol to use as the basis for the customized symbol.
Click Customize to change the default appearance of the selected symbol if desired. This creates a new symbol definition that is added to the file’s resources.
The Customize Symbol dialog box opens.
Parameter
Description
Chair/Table Attributes
Sets the attributes for the chair and/or table symbol
Fill Color
Sets the fill color for the chairs and/or tables
Pen Color
Sets the pen color for the chairs and/or tables
Texture
Select the chair and/or table texture from a library or the current file
Preview
Displays a preview of the symbol the attributes applied
Render Mode
Select whether to preview the symbol in wireframe or Shaded rendering mode
New Symbol Name
Provide a name for the new seating symbol; the new symbol is added to the file’s resources. Names are automatically generated for nested table and chair symbols.
Class
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the seating in the None class to set the attributes from the dialog box.
