Spot03620.pngInserting a television object
Mode
Tool
Tool set
Television
Event Design
The television object simulates CRT and flat screen televisions.
To insert a television:
Click the tool and the insertion modes.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
TV Type
Select the type of TV: flat panel, CRT, or CRT curved
Screen Aspect
Select the aspect ratio of the screen: 4:3 (Standard) or 16:9 (Wide screen); curved CRT screens cannot have a 16:9 aspect ratio
Casing
Select the television model from a library; available models depend on the selected TV Type and Screen Aspect
Size
Displays the television size
Width (image)
Displays the width of the screen image area
Height (image)
Displays the height of the screen image area
Show Coverage Zone
(2D only)
Indicates the viewing area based on the screen size; observers within the area should be able to see the screen
Zone Reference
Calculates the coverage zone based on screen width, height, or diagonal measurement
Max Horiz. Angle/Max. Vert. Angle
Indicates the maximum viewing angle of the screen horizontally and vertically, relative to dead-on
Viewing Height
Enter the height of the average viewer when watching (likely, a seated height)
Near Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the near coverage zone
Far Multiplier
Specifies the multiplier of the reference dimension to determine the extent of the far coverage zone
Edit Screen Image
Opens the Edit Screen Image dialog box to select the image for screen display
Screen Image
Displays the name of the current screen image
Add Adjustable Stand
For flat panel televisions, adds a stand to the screen casing
Stand Height
Specifies the height measurement from the base of the stand to the bottom of the screen casing
Wattage
Enter the required wattage, for power consumption calculations and reporting
Note
Adds a note, which can be placed in the drawing with the Text Options
Text Options
Opens the Text Options dialog box, to enable the display and format the text of labels
Default Text Positions
Restores text labels to their default positions
Classes
Opens the Classes dialog box, to specify class naming for the various portions of the television. This allows portions of the television to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class. Select <Television Class> to place the television element in the same class as the television.
Class Prefix: Specifies an optional default root class naming standard for all television parts; click Assign Default Classes With Prefix to begin all television class names with the prefix, so that they are sorted together.
Assign Default Classes With Prefix: Sets the class names for all television elements to the standard, using the Class Prefix if there is one.
Television elements: For each portion of the television, specifies the class name standard; the class names shown here are applied to the elements.
Update
Updates the object when changes have been made to the Object Info palette parameters
Hanging Point
Select the whether to use a top, middle, or bottom hanging point
Load Information
A television is considered a point load in Braceworks calculations; if the insertion point is on a rigging object, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in Calculations
Includes the television in Braceworks calculations; deselect to exclude the television from participating in structural calculations
Load Group Name
The load category is always Video for video screen objects
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Total Weight
Enter the total weight of the object
Position
Displays the name of the associated rigging object, if the television is attached. Optionally, attach this object to a rigging object, or change the rigging object association, by entering the Position Name of the rigging object. Delete the name to break the association.
For other methods to attach loads, see Making the attachment.
Setting the image on the video screen
Formatting video screen object labels
Concept: Attaching loads to rigging objects
