Editing drains
Mode |
Tool |
Tool set |
Edit
Slab Drainage
Building Shell |
Drains can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
Editing drain properties
To edit drain properties:
Select the slab object.
Click the tool and mode.
Right-click on one or more drains and select Edit Drain(s) from the context menu.
The Drain Settings dialog box opens.
Set the properties.
Parameter |
Description |
Elevation |
Set the drain’s elevation relative to the slab |
Diameter |
Set the drain’s diameter |
ID Label |
Enter the ID label for the selected drain |
Drain Symbol |
Places a drain symbol at the drain location; select the symbol |
Deleting drains
To delete a drain:
Click the Slab Drainage tool.
Right-click on one or more drains and select Delete from the context menu.
