Spot03971.pngPlacing hoist origins
Tool
Tool set
Hoist Origin
Rigging
The hoist origin serves as a reference point for associated hoists; it is used to calculate the location of the hoists for reports (see Creating hoist reports). Several hoist origins can be placed in the drawing, and different hoists can refer to different hoist origins. The coordinates displayed for each hoist are based on its position relative to the assigned hoist origin.
You can insert, a hoist origin before or after placing hoists in the drawing.
To place a hoist origin:
Click the tool, and then click Hoist Origin Symbol on the Tool bar.
The Resource Selector opens to select a hoist origin symbol; double-click a resource to activate it.
Click in the drawing to place the hoist origin.
Parameter
Description
Name
Names the hoist origin, for reference when assigning hoists to the origin, and for label display
Note
Adds a note for informational purposes; the text does not display on the drawing
Symbol
Displays the symbol used to represent the hoist origin
Select Symbol
Opens a Resource Selector to select a different hoist origin symbol; double-click a resource to activate it
Show label in drawing
Displays the hoist origin label in the drawing
Label Offset X/Y
Controls the location of the hoist origin label, which can also be adjusted with the label control point
Classes
Opens the Classes dialog box, to specify class naming for the hoist origin label. This allows the label to be set to visible, grayed, or invisible.
Use the standard class, select a class from the list of classes present in the drawing, or create a new class.
Use Standard Classes: Sets the class name for the label to the standard.
Label: Specifies the class name standard to use for the hoist origin label.
To assign the hoist origin to a hoist in the drawing, select the hoist and specify the Origin on the Object Info palette.
Workflow: Hoists
Placing hoists
