Editing the hydrozone method list
The hydrozone’s Method list contains default options for selection; this list can be customized. Customized lists are saved in the user folder.
The Method can be selected for display in the tag/label object.
To customize the hydrozone method list:
From the Method list in the Object Info palette of a selected hydrozone, select Edit Method List.
The Edit Irrigation Method List dialog box opens.
Parameter |
Description |
Items are displayed in list order; click and drag within the # column to change the order |
Irrigation Method |
Lists the items that display in the hydrozone Method list |
Add |
Adds a new item to the list |
Edit |
Renames the currently selected list item |
Delete |
Deletes the currently selected list item |
Customize the list by adding, renaming, or deleting items. Additional possible hydrozone methods include micro-sprays, root watering systems, soaker hoses, sub-surface drip systems, and so on.
