Spot03839.pngNumbering lighting devices by hanging position
Numbering lighting devices on a hanging position
Lighting devices can be numbered according to the hanging position automatic numbering parameters.
Other numbering options are available from the Spotlight Numbering command; see Numbering light plot objects.
To automatically number the lighting devices on a hanging position:
Select the hanging position.
From the Object Info palette, specify the Starting Number, Increment, Numbering Direction, and, for multi-cell lighting devices, the Multi-Cell Numbering.
Click Auto Number.
The lighting devices are automatically numbered. The Unit Number in the Object Info palette of a selected lighting device displays its number, which can be changed to override the automatic number.
To display the numbers on the drawing, specify a label legend that includes the Unit Number in the label. See Setting up label legends.
Numbering all lighting devices by hanging position
Command
Path
Shortcut
Auto Number Positions
Spotlight
Ctrl+Shift+Alt+O (Windows)
Cmd+Shift+Option+O (Mac)
To automatically number all lighting devices assigned to hanging positions:
Select the command to globally automatically number the lighting devices in the drawing based on the settings in each hanging position.
If hanging positions are selected when the command is activated, only the lighting devices on the selected hanging positions are numbered.
Editing lighting devices
