Spot03932.pngInserting a photometer
Mode
Tool
Tool set
Photometer
Lighting
To insert a photometer:
Ensure that each lighting device contributing to the illumination is focused.
The light beams do not have to be drawn for calculations to be made.
Click the tool and modes.
Click to place the object in the drawing, and click again to set the rotation.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Rotation
Specifies the number of degrees to rotate the object (0.00 is horizontal)
Text Style
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text.
Show Elevation
Displays the object’s elevation along with the photometric value
Show Zero
Displays an elevation value of zero
Show 3D Labels
Displays photometric labels in 3D views
Calculate Using Only Visible Beams
To reduce calculation time, determines the photometric value based on only lighting devices with Draw Beam selected
Use Threshold Settings
Displays the object in a color that corresponds to the specified threshold ranges
Threshold Settings
Opens the Threshold Settings dialog box, to specify the threshold values and the colors for the threshold ranges
Refresh
Refreshes the photometer display after changes have been made to the lighting conditions
After placing the photometer, set its Z value from the Object Info palette; illumination values vary depending on the photometer’s elevation.
Obtaining photometric data
Inserting a photometric grid
Using photometric threshold settings
Focusing lighting devices
