Saving scenes
             Command  |
             Path  |
             Manage Scenes  |
             Spotlight > Visualization  |
To save a scene:
After the lighting properties for all the lighting devices have been set correctly, select the command.
The Manage Scenes dialog box opens.
The Scenes list displays the list of saved scenes. The scenes are sorted by the order in which they were saved. To save the current settings as a scene, click Save. The Save dialog box opens.
             Parameter  |
             Description  |
             Scene Name  |
             Specifies the scene name  |
             Scene Number  |
             Specifies the scene number  |
             Up Time  |
             Enter the time allotted for the lights to increase in intensity, in seconds  |
             Down Time  |
             Enter the time allotted for the lights to decrease in intensity, in seconds  |
Click OK to save the scene. It is added to the Scenes list.
Editing scenes
To edit a scene:
Select the scene from the list in the Manage Scenes dialog box and click Edit.
Make the desired change to the Scene Name or Number, or the Up/Down Time, then click OK to save the change. Confirm the changes.
Removing scenes
To remove a scene:
Select the scene from the list in the Manage Scenes dialog box and click Remove.
Confirm that you wish to remove the scene, then click Yes. The scene is removed from the Scenes list.
Restoring scene lighting parameters
To restore lighting parameters from a scene:
Select the scene from the list in the Manage Scenes dialog box and click Go!.
Confirm that the parameters should be restored. The current light parameters are replaced by those from the scene.
All current levels, colors, positions, and focus points for all the lighting devices will be replaced. Any information that has not been saved will be lost.
