Arch02899.pngConductor Sizing Calculator command
Command
Path
AEC > Electrical
The Conductor Sizing Calculator reports the correct wire size for a given load, based on a single conductor and the length of travel.
To perform conductor sizing calculations:
Select the command.
The Conductor Sizing Calculator dialog box opens.
Parameter
Description
Calculate
Select the type of calculation to perform
Phase Factor
Specifies the phase factor
Wire Properties
Enter the known conductor parameters; values returned by the calculation will are grayed
Type/Manuf.
Select the wire type or manufacturer
Size/Part Number
Select the wire size or the manufacturer part number
Sectional area of the wire, cmil
Enter the cross sectional area of the conductor wire in cmils
Approximate AWG
Enter the approximate AWG (American Wire Gauge) of the conductor
Resistance of conductor material at 75c
Enter the resistance of the conductor material at 75c
Temperature (c)
Enter the operating temperature in Celsius
Amps
Enter the amp rating
Length (ft.)
Enter the conductor length in feet
Type
Select whether the conductor type is Aluminum or Copper, and then enter an Alpha value if other than standard
Voltage Drop
Select whether the voltage drop is a Percentage or Absolute. If a percentage, enter the value.
Voltage
Enter the working voltage
Calculate
Performs the selected calculation
Select the type of calculation to perform, based on the current parameters, from the Calculate list.
Calculation
Description
Wire Size
Provides the sectional area of the wire (cmil) and the approximate AWG for wire sizes below 250 kcmil
Ohms/ft/cmil-ft
Calculates the resistance per sectional area of wire
Voltage Drop
Calculates the voltage drop across the length of the conductor, either as a percentage or absolute value
Phase Factor
Provides the phase factor value of the conductor
Voltage
Calculates the voltage value of the conductor
Ampacity
Determines the amp rating of the conductor
Length of Run
Calculates the allowable length of the conductor specified for the load given
Enter the required values in the fields. Fields where the result will be displayed are grayed. Some calculations require the selection of the wire type or manufacturer, as well as the wire size or part number. When all the required parameter values are complete, the Calculate button becomes available; click to perform the calculation.
The calculation results are displayed. Select another calculation to perform or click Close to exit.
