Arch02901.pngCreating piping runs
Command
Path
Create Piping Runs
AEC > Electrical
Determine the section lengths and amount of material required for piping runs. Piping runs can be drawn by clicking the Piping Run tool from the MEP tool set, by drawing a polygon and selecting the Create Piping Runs command, or by drawing a polyline and selecting the Create Objects from Shapes command (see Creating objects from shapes).
To create a piping run:
Draw one or more polygons to represent the piping run.
With the polygon(s) selected, select the command.
The piping run results are displayed and can be edited from the Object Info palette. An existing piping run can be reshaped with the Reshape tool, and the path polyline can be edited by selecting Edit from the context menu (see Object editing mode).
Parameter
Description
Conduit Size
Specifies the diameter of the conduit
Material
Select the piping run material from the list; this selection can be displayed in the piping run tag
Remarks
Specify any remarks to be displayed in the piping run tag
Show Tag
Displays the piping run Conduit Size and Material
Show Remarks
Displays the piping run Remarks; Show Tag must be selected in order to display the remarks
Length
Displays the length of the piping run
Section Length
Specifies the length of piping run sections; edit this parameter to determine various piping run requirements
Num of Runs
Specify the number of runs; increase the number to estimate the additional material required for a project
Num of Sections
Displays the number of sections required
Couplings
Displays the number of couplings required
Turns
Specifies the type of turns to use for the piping run corners
Use Bends
Bends the conduit and includes the bend in the length
Use Elbows
Counts the number of 45° and 90° elbows and displays the number
Radius
Specify the bend radius
45s/90s
Displays the number of elbow turns (when Use Elbows is selected)
The piping run does not count turns at a junction box (at the location of an electrical object).
