Arch02909.pngCreating custom electrical and communication symbols
The Vectorworks Architect product includes many pre-defined electrical and communication objects in its object library files. If necessary, you can create custom panel and circuiting symbols instead.
Creating custom panels
Electrical, communication, and disconnect panel symbols can be created specifically to fulfill a custom requirement.
To create a panel symbol:
Draw the object to represent the panel.
Select Modify > Create Symbol. Enter a name for the panel and set a destination folder for the symbol as described in Creating symbol definitions.
The panel symbol requires both a panel and circuiting record. If the file does not contain panel and circuiting records, create the records shown in the following tables, as described in Creating record formats.
Record names, particularly the Type field names, are case sensitive.
Panel record
Field
Type
Contents
Name
Text
Must be unique
Type
Pop-up
Must be Electrical, Communication, or Disconnect
Phase
Integer
1
Volts
Text
117
Amps
Integer
100
# of Spaces
Integer
20
Panel Header Line 1
Text
Text placed on Panel Schedule
Panel Header Line 2
Text
Circuiting record
Field
Type
Contents
Name
Text
None
Circuit #
Integer
0
Wire Size
Text
0
Trip
Integer
0
Conduit Size
Text
1/2
V.A. / Watts
Integer
0
Remarks
Text
Panel
Phase / Pole
Integer
2
Voltage
Text
0
Circuit Type
Pop-up
1 for electrical device, 2 for communication device
UID
Text
0
ID
Text
0
From the Resource Manager, right-click the symbol, and select Edit 2D Components from the context menu.
In the Edit Symbol window, deselect all symbol components.
From the Data tab of the Object Info palette, click Attach Record. From the Resource Selector, double-click the panel record format to apply it. Select the panel record and enter the panel information in the fields that display below the Detach button.
Parameter
Description
Name
Enter a unique name for each symbol later, when it is placed on the drawing
Type
Select Electrical, Communication, or Disconnect
Other Panel Parameters
Enter specific information about the panel
Panel Header Line 1/2
Enter text to display on the panel schedule
Click Attach Record and attach the circuiting record to the symbol. Select the circuiting record and enter the circuiting information in the data fields that display.
Parameters
Description
Name
Leave this field blank
Circuit #
Enter 0 (zero)
Other Circuit Parameters
Enter specific information about the circuit
Circuit Type
Select 1 for an electrical symbol, or 2 for a communication symbol
UID
Enter 0 (zero)
Click Exit Symbol at the top right of the drawing window.
Creating custom circuit symbols
Electrical and communication circuit symbols can be created specifically to fulfill a custom requirement.
To create a circuit symbol:
Draw the object to represent the circuitable symbol.
Select Modify > Create Symbol. Enter a name for the circuitable item and set a destination folder for the symbol as described in Creating symbol definitions.
If the file does not contain a circuiting record, create the record shown in the following table, as described in Creating record formats.
Field
Type
Contents
Name
Text
None
Circuit #
Integer
0
Wire Size
Text
0
Trip
Integer
0
Conduit Size
Text
1/2
V.A. / Watts
Integer
0
Remarks
Text
Panel
Phase / Pole
Integer
2
Voltage
Text
0
Circuit Type
Pop-up
UID
Text
0
ID
Text
0
From the Data tab of the Object Info palette, click Attach Record. From the Resource Selector, double-click the circuiting record format to apply it. Select the circuiting record and enter the circuiting information in the fields that display below the Detach Record button.
Parameters
Description
Name
Circuit #
Enter 0 (zero)
Circuit Type
UID
Enter 0 (zero)
If the symbol requires more than one circuit, create and attach a second identical record named Circuiting Record-1.
