Moving objects in the screen plane
Command
Path
Shortcut
Move
Modify > Move
Ctrl+M (Windows)
Cmd+M (Mac)
For information about moving symbols in walls (Design Suite required), see Moving symbols in walls with the Move command.
To move an object in screen plane space by command:
Select the object to move.
Select the command.
The Move Selection dialog box opens. Move the object according to Cartesian or polar coordinates.
Parameter
Description
Cartesian
Specify the distance to move the object; for Cartesian coordinates, select Cartesian and enter the X and Y Offset distances
Polar
Specify the distance to move the object; for polar coordinates, select Polar and enter the Distance and Angle
The object is moved the specified distance.
Moving objects
