The Object Info palette: Data tab
Use the Data tab of the Object Info palette to attach and detach record formats for one or more selected objects, as well as add or change record data.
When an Energos system record format is attached to an object (Vectorworks Architect required), additional Energos Project Settings and Edit Values options become available; see Designating drawing objects as custom Energos systems.
The Data tab also attaches, displays, and allows editing of IFC data (Vectorworks Design Suite required).
If you are using data from an external database, you can create and manage the connection information from this tab.
If you selected multiple objects, select either Multiple Edit or Individual Edit mode, as described in Editing multiple objects.
