Dual object combine
Mode |
Tool |
Tool set |
Shortcut |
Dual Object Combine
Connect/Combine
Basic |
; (semi-colon, Windows) Option+L (Mac) |
The Dual Object Combine mode trims or extends to combine two objects into a single object at their endpoints or intersections. Only open objects, such as lines and NURBS curves and surfaces, can be connected.
To combine two objects:
Click the tool and mode.
Click the first, and then the second, object to combine.
The two objects are trimmed or extended if necessary and combined into one object.
