Line Trim mode
Mode
Tool
Tool set
Shortcut
Line Trim
Split
Basic
L
The Line Trim mode splits 2D objects, NURBS curves/surfaces, solids, and viewports along a screen plane cutting line; it keeps a specified side, and trims away the other side.
To split and trim an object along a cutting line:
Click the tool and mode, and then click the All Objects or Currently Selected Objects mode.
Draw a line through the object to split; the object to be split is highlighted.
An arrow points to the side to be kept. Click to indicate which side of the split line to keep; the other side is trimmed away.
The object is split by the line, and the indicated side remains.
Solids can also be split in Line Trim mode.
Point Split mode
Line Split mode
Splitting or trimming 3D objects
