DesignSeries03546.pngCreating parking reports
Command
Path
Create Report
Tools > Reports
Parking report worksheets can be created for each type of parking tool: parking areas, parking along path objects, and parking spaces. Each type of object has data attached to it that can be used to create a custom report. See Creating reports for more information.
To create a parking report:
Select the command.
The Create Report dialog box opens.
Select the custom report Type and enter a Title.
The Basic Criteria defaults to “Objects with a record.” From the pull-down list, select the type of parking object to include in the report.
From the Possible Columns list, select parking object data to add to the report, such as header style or number of spaces.
Click OK to create the report.
If you have a combination of parking types, either create a separate report for each type, or append the data from the subsequent reports to the original report.
Parking tools
