Creating a plant line
             Command  |
             Workspace: Path  |
             Plant Line  |
             Design Suite: AEC > Plants Landmark: Landmark  |
The Plant Line command creates a freehand plant line along a line, polyline, or polygon. It can be used to represent a single undefined plant, line of plants, or general plant mass. No specific plant symbol information is included in a plant line; use the Landscape Area tool if defined plant areas are necessary (see Creating landscape areas).
To create a plant line:
Select the object (line, polyline, or polygon) with the Selection tool.
Select the command.
The Plant Line dialog box opens. Suggested values are based on the selection’s perimeter.
             Parameter  |
             Description  |
             Segment Length  |
             Maximum length of each plant line segment; longer segments create a rougher plant line appearance  |
             Thickness  |
             Maximum perpendicular distance of each segment; a higher thickness value results in a rougher plant line appearance  |
             Corner Types  |
             Specifies the type of corner to create between segments; each type produces a different plant line effect  |
             Delete original  |
             Removes the object that forms the basis of the plant line  |
Select the desired plant line parameters. The plant line is created. If desired, apply colors, textures, and other attributes to the plant line with the Attributes palette.
