Arch02680.pngInserting a soffit
The soffit accessory has a “pork chop” profile.
To add a soffit accessory to a roof:
From the Create Roof Accessories dialog box, select Insert Soffit, and click Soffit Settings. The Edit Soffit Settings dialog box opens to set the parameters.
Parameter
Description
Recess
Specifies the distance between the bottom edges of the roof rafters and the soffit
Trim Depth
Specifies the distance between the outer edges of the rafters and inside edge of the soffit
Adding roof accessories
