Arch.pngCreating a sheet list
Command
Path
Create Sheet List
Tools > Reports
The Create Sheet List command compiles the current title block border information for use as a sheet list index or worksheet.
To create a sheet list index:
Select the command.
The Create Sheet List dialog box opens.
Parameter
Description
US Arch Title Block Entries
Lists the current title block border objects
Sheet No.
Displays the contents of the current title block selection
Add >
Moves a selected item from the US Arch Title Block Entries list to the Proposed Sheet list
< Remove
Removes a selected item from the Proposed Sheet list and displays it in the US Arch Title Block Entries list
New
Click to open the New List Entry dialog box and add the drawing and title block information to the Proposed Sheet list
Move Up/Move Dn
Moves the selected title up or down in the Proposed Sheet list
Format
Click to open the Sheet List Index Preferences dialog box and specify whether to create the sheet index as a text block or worksheet; also specify formatting criteria
Proposed Sheet List
Lists the proposed title block borders to include in the sheet list
Sheet No./Title
Displays the contents of the current selection for editing
Move the desired title block border entries to the proposed sheet list to create the sheet list, and format the list by clicking Format; select whether to create a text object or worksheet from the list.
Click OK.
If the sheet list index is formatted as a text block, click to select the top left and bottom right corners of the sheet list area; the text wraps to fit within this width. If the sheet list index is formatted as a worksheet, click to add the worksheet to the file.
