Creating loci from a grade object
Command |
Workspace: Path |
Create 3D Loci at Grade Points |
Design Suite: AEC > Terrain Landmark: Landmark Architect and Spotlight: Customize workspace to add command (see Customizing workspaces) |
One or more grade objects can be used to place 3D loci on the current layer. The 3D loci can then be used to create stake objects or a site model (Vectorworks Architect or Landmark required).
To create 3D loci from stake object elevations:
Select one or more grade objects.
Select the command.
A 3D locus is placed at the ends of each selected grade object. The Z-value of the loci match the associated elevation of the grade start or end point.
