Customizing the MacBook Touch Bar
Command |
Path |
Customize Touch Bar |
Vectorworks |
If your MacBook Pro has a Touch Bar, Vectorworks provides controls to allow quick access to all of the tool sets and tools, as well as all of the standard view options. Customize the controls as needed to suit your workflow.
In Vectorworks, select the command.
From the customization window, drag and drop controls to add them to or remove them from the Touch Bar. The following controls are available:
The default set of controls (drag the set to the Touch Bar to remove all customizations)
Buttons for each tool set available in your workspace
Standard Views selection bar and button
Tool Sets A and B; each includes a button to select a tool set and a selection bar to select a tool
Use the Workspace Editor to change the tool order or create a custom tool set specifically for use with the Touch Bar, if desired. If you are familiar with scripting plug-ins, you can create custom tools to provide quick access to scripts and commands.
