Creating headers
Command |
Path |
Roof Framer |
AEC > Framing |
To create headers:
Select the roof object.
Select the command.
The Roof Framer dialog box opens.
Click the Headers tab, and select Create Headers.
Specify the header parameters.
Parameter |
Description |
Header Size |
Specifies the header size in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom frame element sizes). |
Set top of Headers to |
Top of Roof object/component |
Matches the tops of the headers to the top of the roof object, or to the top of the component selected in Use Roof Components |
Bottom of Roof object/component |
Treats the roof object as a roof deck and matches the tops of the headers to the bottom of the roof, or to the bottom of the component selected in Use Roof Components |
Class |
To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating classes) |
Classes |
Edits class attributes |
Object Attributes |
Specifies the header attributes |
