Arch02793.pngCreating hip and valley rafters
Command
Path
Roof Framer
AEC > Framing
To create hip and valley rafters:
Select the roof object.
Select the command.
The Roof Framer dialog box opens.
Click the Hips/Valleys tab, and select Create Hips and Valleys.
Specify the hip and valley rafter parameters.
Parameter
Description
Hip/Valley Size
Specifies the size of the hip and valley rafters in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom frame element sizes).
Set top of Hips and Valleys to
Top of Roof object/component
Matches the tops of the hip and valley rafters to the top of the roof object, or to the top of the component selected in Use Roof Components
Bottom of Roof object/component
Treats the roof object as a roof deck and matches the tops of the hip and valley rafters to the bottom of the roof, or to the bottom of the component selected in Use Roof Components
Class
To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating classes)
Classes
Edits class attributes
Object Attributes
Specifies the hip and valley rafter attributes
Setting class properties
Framing a roof
