Creating plates
             Command  |
             Path  |
             Roof Framer  |
             AEC > Framing  |
To create plates
Select the roof object.
Select the command.
The Roof Framer dialog box opens.
Click the Plates tab, and select Create Plates.
Specify the plate parameters.
             Parameter  |
             Description  |
             Size  |
             Specifies the plate size in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom frame element sizes).  |
             Rafter Connection  |
             Flush to Top of Plate  |
             Sets rafters flush to the top of the plate  |
             Notched for Plate  |
             Notches the rafters to set on the plate; enter the Notch Depth, by default this is set to 1.5”. The depth of the notch should not exceed one-third of the rafter depth.  |
             Class  |
             To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating classes)  |
             Classes  |
             Edits class attributes  |
             Object Attributes  |
             Specifies the plate attributes  |
