Arch02784.pngCreating purlins
Command
Path
Roof Framer
AEC > Framing
To create purlins:
Select the roof object.
Select the command.
The Roof Framer dialog box opens.
Click the Purlins tab, and select Create Purlins.
Specify the purlin parameters.
Parameter
Description
Purlin Size
Specifies the purlin size in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom frame element sizes).
Elevation of First Purlin
Specifies the elevation above finished floor of the bottom of the lowest purlin
Elevation of Last Purlin
Sets the elevation from the top of the roof to the last purlin
Create Purlins by:
Number of Purlins
Indicates the number of purlins to create; the purlins are evenly spaced between the first and last purlins
Distance Between Purlins
Specifies the distance between purlins; the number of purlins created is based on this value
Purlin Position
Top of Rafter
Matches the tops of the purlins to the top of the roof object, as for roof tile supports
Bottom of Rafter
Matches the tops of the purlins to the bottom of the roof, as when the purlins support the rafters
Purlins Start at the Lower End of the Rafter
Sets the elevation of the first purlin to start from the lower end of the rafter
Rotate Purlins to Roof Slope
Rotates the purlins so that they match the slope of the roof
Bearing inset
Specifies the depth at which the purlin is notched into the rafters; if purlins are rotated this field is grayed since the inset only applies to horizontal purlins
Class
To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating classes)
Classes
Edits class attributes
Object Attributes
Specifies the purlin attributes
Setting class properties
Framing a roof
