Creating rafters
             Command  |
             Path  |
             Roof Framer  |
             AEC > Framing  |
To create rafters:
Select the roof object.
Select the command.
The Roof Framer dialog box opens.
Click the Rafters tab, and select Create Rafters.
Specify the rafter parameters.
             Parameter  |
             Description  |
             Rafter Size  |
             Specifies the rafter size in width x height, in current file units. Sizes can be edited by selecting Edit List (see Custom frame element sizes).  |
             Dormer Rafter Size  |
             If the roof contains dormer windows, enter the size, in Width x Height, of the dormer rafters  |
             Minimum Spacing  |
             Specifies the minimum distance allowed between rafters  |
             Maximum Spacing  |
             Specifies the maximum distance allowed between rafters; for consistent rafter spacing of the entire roof, the Minimum and Maximum Spacing values should be equal  |
             Set top of Rafters to  |
             Top of Roof object/component  |
             Matches the tops of the rafters to the top of the roof object, or to the top of the component selected in Use Roof Components  |
             Bottom of Roof object/component  |
             Treats the roof object as a roof deck and matches the tops of the rafters to the bottom of the roof, or to the bottom of the component selected in Use Roof Components  |
             Match Rafters across Ridges/Hips/Valleys  |
             Ensures that opposing rafters meet on the roof ridges, hips, and valleys  |
             Class  |
             To control appearance and visibility, select a class from the list of classes present in the drawing or create a new class (see Creating classes)  |
             Classes  |
             Edits class attributes  |
             Object Attributes  |
             Specifies the rafter attributes  |
