Round tubing
Mode
Tool
Tool set
Round Tubing
Detailing
The Round Tubing tool and Round Tubing - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To create round tubing:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Series
Select the desired series to display the appropriate nominal sizes
Size
Select the round tubing size
Length
(Design Suite required)
Enter the length of the 3D round tubing
Draw Center Lines
Select whether to draw the 2D round tubing with center lines
Place Locus at Centroid
Select whether to draw a locus at the centroid of the 2D round tubing
Custom Size
Select this option to enable fields for specifying a custom round tubing size
Outside Diameter
Displays the outside diameter of the tubing, or if Custom Size is selected, allows entry of a custom value
Wall Thickness
Displays the wall thickness of the tubing, or if Custom Size is selected, allows entry of a custom value
Section Properties
Section properties are automatically calculated and displayed based on inch units for imperial shapes and millimeter units for metric shapes (regardless of the units selected and Show Unit Mark setting in the Units dialog box)
Area
Displays the round tubing area
About Axis X-X/Y-Y
Moment of Inertia
Displays the moment of inertia about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Section Modulus
Displays the section modulus about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Radius of Gyration
Displays the radius of gyration about both the horizontal (X-X) and vertical (Y-Y) centroidal axes
Structural shapes and details
