Shaft break 2
             Tool  |
             Tool set  |
             Shaft Break 2
             Detailing  |
To insert a shaft break 2 object.
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
             Parameter  |
             Description  |
             Shaft Diameter  |
             Specify the diameter of the shaft break object  |
             Width of Break  |
             Specify the width of the shaft break object  |
             Configuration  |
             Select Solid or Hollow
             Wall Thickness  |
             For hollow shaft break configurations, indicate the thickness of the shaft wall  |
