Additional plug-in object style and instance options
For plug-in object styles and plug-in object instances (whether styled or unstyled), you can control some settings regardless of whether the plug-in object is, for example, a window or a title block border. Because these settings are inherent to plug-in objects and not to the object type, they are not accessed from the object properties dialog box.
To set the class, the 2D component and cut plane display, or the wall insertion settings for a plug-in object style or plug-in object instance:
Right-click on the resource in the Resource Manager or the instance in the drawing and select Plug-in Object Style Options or Plug-in Object Options from the context menu.
The Plug-in Object Style Options dialog box or Plug-in Object Options dialog box opens.
If you are setting options for the plug-in object style, set whether the parameters will be defined by style or by instance, and set the options (see Concept: Plug-in object styles). If you are setting options for an instance, verify the by style/instance settings to confirm that you can change the settings for this instance; however, the by style/instance setting can only be established from the Plug-in Object Style Options dialog box.
As with regular plug-in object parameters, when the options on these dialog boxes, including Class, are set by instance, they can be edited at any time. When set by style, any change to the plug-in object style’s settings changes all the objects in the file that use the style.
Parameter |
Description |
Class |
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. When <Active Class> is selected, Class must be set by instance. |
2D Components |
Indicates whether the 2D components are defined by the style or can be set by instance. See Creating 2D components for symbol definitions and plug-in objects to create the 2D components themselves. |
Mirror opposite view graphics for empty 2D Components |
If a 2D component contains no graphics, views of that side of the plug-in object mirror the opposite 2D component graphic (if available); if the opposite 2D component graphic does not exist, the 3D component displays. If a component is designed for viewing at a particular detail level, you may choose to leave the mirrored view empty and select this setting, rather than taking time to draw the mirrored component. For symbol definitions, this setting is located on the Create Symbol dialog box and Symbol Options dialog box. |
Top/Plan View Component |
Select the 2D component graphic to display in Top/Plan view. For symbol definitions, this setting is located on the Create Symbol dialog box and Symbol Options dialog box. |
Horizontal/Vertical Section Cut Plane (Design Suite required) |
Set how the plug-in object displays when it intersects the cut plane in horizontal and vertical section viewports. See Setting the section cut plane display for plug-in objects for more information about these settings. |
Wall Insertion |
For plug-in object types that are can be inserted into walls, set the insertion options |
Insert Location |
Specify where to insert the object relative to the wall or its core component. <Nearest Wall Edge on Insertion> places the insertion point on the wall edge closest to the point clicked for insertion. This selection automatically sets the parameter by instance. |
Offset |
Enter the offset of the insert perpendicular to the wall's path |
Use wall closure |
Allows the object to use wall closures; available only for object types that can include wall closures, such as doors and windows. See Wall closure settings for information. |
Wall Closure Profile Offsets |
Opens the Wall Closure Profile Offsets dialog box to set the interior and exterior profile offsets for the wall opening at the insert |
Exclude Wall Closure From |
Select any edges to exclude from wall closure settings |
Top/Plan View Cut Plane |
Select the cut plane location relative to the object to determine how the wall opening edges are shown in Top/Plan view |
Offset |
Enter the cut location offset, if any |
