Editing interior elevation viewports
Interior elevation viewports are technically section viewports, and they can be edited using many of the same techniques described in Modifying section viewports and section lines.
Moving the marker with click-and-drag does not affect the placement of the section lines that define the viewports, but rotating the marker using the Rotate tool rotates all the section lines associated with the marker.
To edit the individual section lines that define the viewport, either double-click the associated interior elevation marker or click Edit Section Lines from the marker’s Object Info palette to enter Object editing mode. Then edit the lines using the control points and the Selection tool and Reshape tool as described in Modifying section lines graphically.
You can crop existing interior elevation viewports. If the section lines that define the viewport are edited after a viewport is cropped, you may need to remove or change the crop to get the desired result (see Cropping existing sheet layer or design layer viewports).
