Wall feature properties
After a wall feature has been created, it can be edited from the Object Info palette. Alternatively, right-click on the feature and select Properties from the context menu.
In addition to the parameters available when the feature is created, the following options are available.
Parameter |
Description |
Flip |
Flips the wall feature to the other side of the wall |
Set Position |
Activates the Move by Points tool in Reference Point mode, to move the wall feature a specified distance along the length of the wall (see Moving symbols in walls with the Move by Points tool) |
Cut Plane (Architect required) |
Displays the design layer cut plane elevation when the design layer cut plane is enabled (see Setting design layer properties); when it is disabled, sets the elevation of the wall feature cut plane |
(3D object projections only) |
If Show Extents Below Cut Plane or Show Extents Above Cut Plane is selected, opens the Extents Attributes dialog box to allow editing of the 3D object outlines shown for the areas below and above the cut plane |
