DesignSeries02547.pngCapped wall component joins
Mode
Tool
Tool set
Shortcut
Capped Join
Component Join
Building Shell
Alt+Shift+J (Windows)
Option+Shift+J (Mac)
Like the T Join mode, the Capped Join mode extends or shortens one wall component until it intersects with a second component. The component end is capped at the point where it joins the other wall.
To join wall components with the Capped Join mode:
Click the tool and mode.
Select the component within the wall segment to join.
Select the second wall segment to join. The component to be joined is highlighted.
Repeat steps 2 and 3 for each component within the wall segment that needs to be joined.
Joining wall components
Hiding wall components
