SpotlightSetting custom truss parameters
Some truss parameters depend on manufacturer data or custom specifications. These parameters can be viewed and edited from the Truss Properties dialog box, either when Modifying truss symbol data or Creating a custom truss symbol.
Different parameters display for straight, corner, hinge, and circular (curved) trusses. Select the truss type from the Geometry Type list, and edit the parameters as needed.
Truss properties: Straight Truss
Parameter
Description
Object Data
Type
Enter a truss system name
Name
Specify a catalog name for the truss element
Length (L)
Enter the installation length
Total Weight
Enter the total weight of the truss
Distributed Weight
Displays the distributed weight of the truss; this is calculated automatically based on the Length and the Total Weight. Changes here also affect the Total Weight value.
Vertical symbol
Indicates that the symbol will be inserted as a vertical truss; if deselected, a horizontal truss is assumed
Cross Section Data
UID
Displays the ID of any currently selected cross section
Change Cross Section
Opens the Cross Section dialog box to select a cross section file to associate with the truss, as described in Specifying cross section data
Height/Width
If a generic (rigid) cross section was selected, or a cross section is not specified, enter the total installation height and width of the truss; otherwise, the height and width from the selected cross section display
Connectable with
Specifies the Type of cross section that the truss can connect to. The truss must be connectable with its own type. To list more than one cross section, separate them with semi-colons.
Connection
Start/End
Select the type of connection for each end of the truss, or select No Connection; see Concept: Creating a connected rigging system. At insertion, Auto Connect mode uses the selections for proper truss connection.
Roll Angle
Sets the connection angle for triangle trusses. The truss object is rotated on its X axis. Up-pointing triangle trusses should be set to 0 (zero) degrees; down-pointing triangle trusses should be set to 180 degrees.
Geometry
Displays a typical truss to show the parameter locations
Edit Magnets in Symbol
Opens the truss symbol in Object editing mode to adjust the magnets. See Adjusting magnets for more information.
Truss properties: Corner Truss
Parameter
Description
Object Data
Type
Name
Total Weight
Enter the weight of the truss
Cross Section Data
UID
Height/Width
If a generic cross section was selected, or a cross section is not specified, enter the total installation height and width of the truss; otherwise, the height and width from the selected cross section display
Connectable with
Connection
Select the type for each connection and set its connection angle, or select No Connection; see Concept: Creating a connected rigging system. At insertion, Auto Connect mode uses the selections for proper truss connection. Depending on the selected Corner Type, various connection combinations become available.
Geometry
Displays a typical truss to show the parameter locations; enter the values below the diagram
Corner Type
Select the type of corner geometry; the diagram adjusts to display the required parameters
Parameter values
Depending on the selected Corner Type, different parameters are required. The diagram indicates where the parameters are located. For typical corners, length values are required. For Custom types, up to six points can be defined. Specify the coordinates at the middle of the truss where the center lines cross. Then select the corners of the connection points on the truss, and specify their coordinates relative to the insertion point.
Truss properties: Hinge Truss
Parameter
Description
Object Data
Type
Name
Total Weight
Enter the total weight of the truss element
Minimum Angle (A)
Specify the minimum angle for the hinge truss
Maximum Angle (A)
Specify the maximum angle for the hinge truss
Cross Section Data
UID
Height/Width
Connectable with
Connection
Start/End
Roll Angle
Geometry
Hinge Type
Select the type of hinge geometry; the diagram adjusts to display the required parameters
Parameter values
Depending on the selected Hinge Type, different parameters are required. The diagram indicates where the parameters are located.
Truss properties: Circular Truss
Parameter
Description
Object Data
Type
Name
Diameter (D)
Enter the outer diameter of the circular truss
Angle (A)
Specify the arc angle of the truss from the start point to the end point
Insertion point is center point
Indicates that the center point of the truss is also its insertion point
Total Weight
Distributed Weight
Displays the distributed weight of the truss; this is calculated automatically based on the Length and the Weight. Changes here also affect the Total Weight value.
Cross Section Data
UID
Height/Width
Connectable with
Connection
Start/End
Roll Angle
Geometry
Placing trusses
Concept: Truss magnets
Modifying trusses and systems
