Adding a rack ruler
           Tool  |
           Tool set  |
           Rack Ruler
           Layout  |
The rack ruler measures the height of equipment racks by placing a 2D ruler on the drawing with both drawing unit and rack unit markings. The ruler measurements are displayed in the units specified in the document settings (see Units settings: Dimensions pane).
To place a rack ruler:
Click the tool.
Click Preferences to specify the tool’s default parameters. The parameters can be edited later from the Object Info palette.
           Parameter  |
           Description  |
           Height (RU)  |
           Sets the height of the rack ruler in rack units  |
           Base Offset  |
           If the rack ruler measurements should be offset from the base of the equipment rack, enter the offset value  |
Click once to place the rack ruler; click a second time to set the rotation.
