Creating a layout room
           Mode  |
           Tool  |
           Tool set  |
           Rectangle
 Polygon
           Layout Room
           Layout  |
The layout room is an optional 2D container for equipment racks. 2D racks placed within the boundary of the room will inherit the Room ID parameter as a read-only parameter denoting location.
To create a layout room, either use the Layout Room tool, or create a closed 2D shape and then select the Create Objects from Shapes command (see Creating objects from shapes).
To create a layout room:
Ensure that the current design layer is Rack Elevation.
Click the tool and select a drawing mode.
Do one of the following:
In Rectangle mode, draw the rectangular room shape, similar to drawing a rectangle in Corner to Corner mode.
In Polygon mode, draw a closed polygon shape.
Place polygonal layout rooms on architectural floor plans to define the location of non-rack equipment.
In the Object Info palette, provide the Room ID.
Edit the layout room by double-clicking on it and using the Reshape tool.
