Placing a basic device or device symbol
  The Device tool places a basic device that you can customize, or a device symbol definition. The tool also transfers device properties from one device to another.
           Mode  |
           Tool  |
           Tool set  |
           Basic Device
 Insert Device
           Device
           Schematics  |
           Mode  |
           Description  |
           Basic Device
           Inserts a generic device with no sockets, ready to customize  |
           Insert Device
           Inserts device from the Device Symbol list of symbol definitions  |
           Pick up Attributes
           Copies device characteristics for transfer; see Transferring device properties  |
           Apply Attributes
           Pastes device characteristics  |
           Single Click (Insert Device mode)
           Places a single device at the click location  |
           Linear Array (Insert Device mode)
           Places an array of devices along the drawn line  |
           Device Symbol (Insert Device mode)  |
           Opens the Resource Selector to select a device resource for placement; double-click a resource to activate it  |
           Eyedropper Transfer Preferences
           Sets the default transfer items and methods  |
To add a device:
Click the tool.
Do one of the following:
Click Basic Device mode to place a basic, generic device.
Click Insert Device mode, and then click Device Symbol on the Tool bar to select a resource from the Resource Selector.
Symbols from the System Symbols folder are not available for placement by the Device tool.
Place the device. The placement method depends on the selected mode and sub-mode.
In Basic Device mode, click once to set the start point; move the cursor to the opposite corner until the desired size is previewed. Click to insert the device.
In Single Click sub-mode, click once to place the selected symbol instance.
In Linear Array sub-mode, click once to start the array; move the cursor to set the distance and direction of the linear array. Press the Shift key to constrain to the horizontal or vertical direction. The preview indicates the spacing and placement of the objects; the floating Data bar shows the Count. Click to place them.
In Insert Device mode with a symbol selected, the device can be placed in the drawing on its own or placed into an existing circuit. To be placed into a circuit, the device needs an input on the left and and output on the right, horizontally opposite.
As the devices are placed, they are automatically numbered. Sequential autonumbering continues for devices with the same name prefix. Select an existing device, and then select the Device tool, to restart the numbering from that device on.
Device parameters
The device parameters can be edited from the Object Info palette. To complete a basic device, the next step is to add sockets as described in Adding sockets, loops, and terminators.
             Parameter  |
             Description  |
             General  |
             Device Name  |
             Enter the name of the device  |
             Symbol  |
             Displays the symbol selected for the device label; select a different symbol definition from the list if desired. The options include different locations for the tag and description labels.  |
             Display Tag  |
             Enter the tag name (normally this is the name of the device) for display on the drawing  |
             Description  |
             Enter a description, such as the manufacturer and model name, for display on the drawing  |
             Manufacturer  |
             Enter the make and model for use in reports  |
             Save as Symbol  |
             Saves the device (and its sockets) as a symbol definition that can be accessed for editing from the Resource Manager, and placed on the drawing with Insert Device mode. Enter the name of the new symbol.  |
             Save to Database  |
             Opens the Device Builder dialog box. You can review and, if necessary, edit information about the device and its sockets. The device is saved to the database, and it is available in the Device Builder dialog box. (For more information, see Saving a device to the database.)  |
             Physical  |
             Specify the dimensions of the device (height/width/depth), the power requirements in watts, the weight in kilograms, the height in rack units, and the rack width (for more information, see the Rack Width description in Placing equipment). Devices with dimensions of 0 are considered virtual devices, which cannot be associated with equipment items.  |
             Configuration  |
             Modular  |
             Indicates that the device is a module that fits in a rack frame  |
             Number of slots  |
             For modular devices, enter the number of frame slots required in a rack frame  |
             Location  |
             If an associated equipment item already exists in the layout, displays the device location; otherwise, if you want to assign the device to a layout, enter the location for the corresponding equipment item  |
             Room  |
             Enter (or displays) the name of the room  |
             Rack  |
             Enter (or displays) the name of the equipment rack; the rack name displays on the device  |
             Rack U  |
             Select (or displays) the position of the device in rack units; the value displays on the device  |
             Edit Device Array  |
             This functionality is not available for this type of device  |
