Placing a rack frame
           Tool  |
           Tool set  |
           Rack Frame
           Layout  |
A rack frame is placed within a rack and it becomes associated with the rack, inheriting the rack’s ID/location and moving along with it. Rack frames are used for modular equipment items. A rack frame can optionally be inserted stand-alone.
To place a rack frame:
Click the tool.
Click to place the rack frame in the drawing; normally, place the rack frame within an equipment rack. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
             Parameter  |
             Description  |
             General  |
             Name  |
             Enter a rack frame name for labels and reports  |
             Manufacturer  |
             Make/Model  |
             Enter the manufacturer’s make and model information  |
             Physical  |
             Mounting  |
             Select whether the rack frame mounts to the front or rear of the equipment rack (useful for 3D views)  |
             Height RU  |
             Select the height of the frame in rack units  |
             Depth/Power/Weight  |
             Specify the rack frame’s size, power requirements, and weight  |
             Configuration  |
             Slots H/V  |
             Enter the number of slots in the frame, in the horizontal and vertical direction  |
             Power Supplies  |
             Select the number of power supplies in the frame  |
             PSU Location  |
             Select the location of the power supply units  |
             PSU Size  |
             Enter the size of each power supply unit  |
             Location  |
             Displays the containing layout room and equipment rack ID, as well as the rack location in rack units  |
