Renumbering devices and sockets
           Command  |
           Path  |
           Renumber Devices or Sockets  |
           ConnectCAD > Drawing  |
Renumbering devices and sockets is useful when designing a new system with numbering that depends on the device and socket names. This command renumbers the Device Name or Socket Name and the Display Tag suffix. For existing systems, use caution when renumbering, since the associated cable numbers should match the cable numbers that have already been installed on site. Optionally, this command adds a custom prefix to the Device Name or Socket Name and/or the Display Tag.
To renumber selected devices or sockets in the drawing:
Select the devices or sockets to renumber. You cannot select a mixture of both.
Selected devices are renumbered in the order in which they were drawn.
Select the command.
The Labeling Options dialog box opens. Select either numeric or alphabetical labeling.
             Parameter  |
             Description  |
             Numeric  |
             Select the starting number; if the desired number is not in the list, select Custom to specify a custom start number in the Add New Start Number dialog box  |
             Increment by  |
             Select the increment interval  |
             Format  |
             Select the number of leading zeros  |
             Delimiter  |
             Select a delimiter character to place before the number  |
             Alpha  |
             Start  |
             Select the starting letter  |
             Increment by  |
             Case  |
             Choose either upper or lower case letters  |
             Delimiter  |
             Select a delimiter character to place before the letter  |
             Prefix (Optional)  |
             Name  |
             Adds a prefix to the Device Name or Socket Name  |
             Display Tag  |
             Adds a prefix to the socket or device Display Tag  |
             Numbering Direction  |
             Select the numbering direction. The stacking order of the objects is usually the order in which they were added to the drawing.  |
             Example  |
             Displays a preview of the selected labeling options  |
