Converting objects to dimensions
Command
Path
Convert Object to Dimension
Modify > Convert
To convert a line, double line, or arc to a dimension:
Select the object to convert.
Select the command.
The object is converted to a dimension. Lines change to linear dimensions, and arcs change to angular dimensions.
Editing dimensions
