Customizing seating symbols
It is possible to customize the seating symbol attributes to create a new hybrid symbol definition for use in seating sections.
From the Arrangement pane of the Seating Section Settings dialog box, select a Seating Symbol to use as the basis for the customized symbol.
Click Customize to change the default appearance of the selected symbol if desired. This creates a new symbol definition that is added to the file’s resources.
The Customize Symbol dialog box opens.
Parameter |
Description |
Chair/Table Attributes |
Sets the attributes for the chair and/or table symbol |
Fill Color |
Sets the fill color for the chairs and/or tables |
Pen Color |
Sets the pen color for the chairs and/or tables |
Texture |
Select the chair and/or table texture from a library or the current file |
Preview |
Displays a preview of the symbol the attributes applied |
Render Mode |
Select whether to preview the symbol in wireframe or Shaded rendering mode |
New Symbol Name |
Provide a name for the new seating symbol; the new symbol is added to the file’s resources. Names are automatically generated for nested table and chair symbols. |
Class |
To control appearance, select a class from the list of classes present in the drawing, or create a new class. Leave the seating in the None class to set the attributes from the dialog box. |
