LandmarkPlant database field mapping
When plant data is imported into the plant database with the File > Import Records > File database command, field mapping is required (see Importing plant database information). Certain fields must be used during mapping for the plant catalog to function properly when exported for use with the Vectorworks Landmark product. All significant Vectorworks fields have a VW prefix.
The number of available plant data fields varies, depending on global region.
Target field name
Notes or example values
Target field name
VW Autumn Color
VW Height
VW Bloom Time
Also referred to as Season
VW Landscape Use
Border, Hedge, Shade Tree...
VW Category
Shrubs, Herbs, Trees...
VW Latin Name
Also known as the plant botanical name
VW Climate Zone
Arid, Semi Arid, Dry...
VW Light Range
Deep Shade, Shade, Sun, Full Sun
VW Code
VW Other Tolerance
VW Comments 1
VW Other Use
VW Comments 2
VW Persistence
Deciduous, Semi-Evergreen, Evergreen...
VW Comments 3
VW pH Range
Acidic, Adaptable
VW Common Name
VW Price
VW Favorites
VW Region
VW Flower Characteristics
Double, Erect, Fragrant, Horizontal...
VW Region Notes
VW Flower Color
VW Season Notes
VW Foliage Characteristics
Aromatic, Broad-leaf, Evergreen, Fronds, Small leaves...
VW Size Notes
VW Foliage Color
VW Soil Range
Bark, Sand, Sandy loam, Potting soil...
VW Fruit Characteristics
Acorns, Berry, Catkins, Cones
VW Spread
VW Fruit Color
VW Tolerances
Cold Frost, Drought, Heat...
VW Growth Habit
Arching, Broad-domed, Columnar, Climber...
VW Used in Project
VW Hardy Zone
1–11 (from USDA zone mapping)
VW User notes
