LandmarkShow or hide plant details
Command
Path
Show or Hide Plant Details
View > Show
The Show or Hide Plant Details command controls the visibility of the outline, massing, and shadow parameters set on the plant settings Appearance pane or the Object Info palette (see Plant settings: Appearance pane).
These effects display in Top/Plan view only. In a complex drawing with many plants, these settings can take a significant amount of time to display and edit, and it is useful to toggle the effects on and off.
To show or hide the plant details:
Select the command.
If the plant details are currently hidden, this command displays the outline, massing, and shadows of all plant objects with those parameters set. If the plant details are currently visible, this command hides the effects. The Outline selection is saved for the plants, even when hidden.
