LandmarkViewing plant database records
Each plant entry and its associated botanical information is considered a “record” in FileMaker. Several view modes display the records in ways designed to facilitate performing related tasks. When the plant database first opens, the records operate in Browse mode, with Forms displayed.
To familiarize yourself with the different display modes, and view the plant records in a variety of ways:
Open the plant database as described in Accessing the plant database.
Select the View > Status Toolbar database command to enable viewing controls and status at the top of the record form. Many of these items can also be found on the View and Records menu.
From the Status toolbar and the View menu, select the view mode and layout options depending on the task to accomplish.
Mode or view option
Description
View Mode
Browse
Displays plant record information and allows editing
Find
Displays a blank form for specifying search criteria
Preview
Displays plant record information as it will be printed
View as Form
Displays each record as an individual form or “page”
View as List
Displays records consecutively in a scrollable list
View as Table
Displays each record as an item in a table, for sorting and reordering
Layout
Data View
List View
Displays limited plant data for each plant, for sorting and reordering
Web View
Displays a special browser (using the default system browser) for locating plant images and information
Records Found toggle and status
After a search, the green toggle button displays an approximate pie chart and the number of records found; click the green pie chart button to toggle the display to records that are not in the found set. The sort status is also indicated.
Show All
Clears the results from a search, displaying all records
New Record
Adds a plant record to the database
Delete Record
Deletes the currently selected record from the database
Find
Switches to Find mode layout, for searching
Find menu
Allows searches to be saved, modified, recalled, and cleared
Sort
Opens the Sort Records dialog box, for determining the sort order for the plant records, or for unsorting the records
Quick Find
Searches for the text entered or recent searches, without switching to Find mode
Preview
Displays the records in a Print Preview mode
The plant database
Searching for plants
