Locating a resource from the drawing
Command
Path
Locate [resource type] in Resource Manager
Context menu
Use the Locate in Resource Manager command to quickly locate resources displayed in the drawing area. This command does not work for record formats or scripts.
To locate a resource from the drawing:
Select the resource (or object containing a resource, such as a rectangle with a hatch) to be located. Select the command.
The Resource Manager automatically navigates to the resource and selects it.
Searching for a resource
