Creating a break line
           Mode  |
           Tool  |
           Tool set  |
           Modes for Creating single lines  |
           Break Line
           Dims/Notes  |
The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a planar pad from grade limits.
To draw a break line:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
             Parameter  |
             Description  |
             Break Style  |
             Selects the style of the break line (Straight, Curved, or Arc)  |
             Break Width  |
             Indicates the width of the break only  |
             Break Height  |
             Indicates the height of the break only  |
             Break Radius  |
             Sets the radius of the break only  |
             Number of Breaks  |
             Indicates whether a single or multiple break should be drawn  |
